112 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to change the default ground color ?
Wed, Feb 25, 2009 at 10:27:21 AM | how to change the default ground color ?
querosaber
I did the toposuface - site and when redering , with sky apears out of the toposurface and is not the sky a dark color .
thnks a lot
Wed, Feb 25, 2009 at 11:16:55 AM | how to change the default ground color ?
If something in Revit says default, then you haven't set it yet.  Every surface in Revit can have a material associated with it.  When you create your topo surface, you can set it in the properties then.  Now, select your topo surface, goto element properties and set the materials for your surface.
Wed, Feb 25, 2009 at 11:48:38 AM | how to change the default ground color ?
querosaber
sorry if i did explain well.. i cnat write english very well
i know change the toposurface, i cant change is out of tposurface ( maybe bakground ) ..
when i render and use a sky and a toposurface ( all render ok ) but out my objects crated by me apears at gray.
i cant change this color
Wed, Feb 25, 2009 at 11:54:17 AM | how to change the default ground color ?
Same rules apply.  If you created the families, you had a chance to assign properties to them.  Edit the families and assign properties to the extrusions..... other than default.
Wed, Feb 25, 2009 at 12:07:08 PM | how to change the default ground color ?
querosaber
AND THE BACKGROUND ? HOW YOU CHANGE THE COLOR ?
THANKS A LOT , AND GOOD WORK .
Wed, Feb 25, 2009 at 12:45:10 PM | how to change the default ground color ?
4 Stars: 203 Votes
I don't understand very well you english but are you trying to ask "How you change in the render process the color of the Background"??? Podes falar Português se quiseres...
Wed, Feb 25, 2009 at 5:15:16 PM | how to change the default ground color ?
querosaber
o que pretendia era saber como mudo a cor de fundo , mas tb usando o céu.
ou seja quando uso o céu e  usando uma pespectiva onde se vê tb o ground floor . ele aparece em cinza , ou seja o terreno fora da toposurface criada. não sei se me faço entender.
 como faço pra mudar o cor  background  usando tb o sky predefinido pelo revit?
 how i change the back gorund color  and use a t same time the sky ???
Wed, Feb 25, 2009 at 8:27:30 PM | how to change the default ground color ?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Olá querosaber, pois infelizmente o que tu queres fazer não é possível, tu podes mudar sómente o tipo de céu ou sómente o cor do fundo sem céu mas não as dois coisas. Mas o que tu podes fazer é criar como tu já sabes, uma imagem .tiff ou .png, logo crias a drafting view e colocas o fundo que queras.....
Edited on: Thu, Feb 26, 2009 at 7:51:14 AM
Thu, Feb 26, 2009 at 3:55:41 AM | how to change the default ground color ?
4 Stars: 203 Votes
Erland, tás a melhorar no Português....
Thu, Feb 26, 2009 at 8:24:48 PM | how to change the default ground color ?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
LOL, pois vou "pouquinho a pouco" com o português sempre.....A propósito Typhoon, dentro de pouco te mando outras árvores que tenho por aqui.......cuida-te!!!
Can I change the color of the Default Wall?
Fri, May 4, 2012 at 11:36:18 AM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:23 AM
16
How to change Revit Color Fill Legend default text - "No colors defined"?
Sat, Oct 26, 2024 at 9:27:45 AM
Rendering - Changing Ht of Ground plane does not 'stick'
Thu, Mar 10, 2005 at 4:35:09 PM
massing - default color not visible
Tue, Jun 9, 2009 at 9:28:38 AM
Page generation time: 1.0198
