158 Users Online (157 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> dimensions in 3d
Mon, Feb 23, 2009 at 3:36:28 PM | dimensions in 3d
RainaMc
RainaMc Avatar
Working in 2008.  Can Revit dimension in 3D?  I can't seem to dimension in the z-axis am I doing something wrong?
Thank you,
Mon, Feb 23, 2009 at 3:50:38 PM | dimensions in 3d
wheelergc
You can't dimesion in a 3d view.  You can dimesion in elevation or section.
Fri, Mar 27, 2009 at 12:11:11 AM | dimensions in 3d
DimensionHelper
Sure you can.
There is an import concept for dimension in 3d, that is work plane. Dimensions will only be created on current work plane. You can see current work plane by click the Work Plane Visibility button.
Take dimension between faces for example. The faces must be 1) perpendicular to the work plane; 2) parallel to each other. Otherwise the faces will not be pickable as dimension reference. Basically you can dimension all parallel faces by choosing proper work plane first.
If it still doesn't work, let me know. And also any suggestion on what dimensions in 3d should be is welcome. Thanks.
Thu, Apr 2, 2009 at 7:45:26 AM | dimensions in 3d
JRMello
Here's an example of dimensioning in 3D. This item was small enough and simple enough that I decided to get the specs out with one drawing rather than 3 or 4.
Thu, Apr 2, 2009 at 10:25:32 AM | dimensions in 3d
RainaMc
RainaMc Avatar
Thanks dimension helper.
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:37 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:53 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:57 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:52 AM
Page generation time: 0.2578
