74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Orient a view perpendicular to a work plane
29 Posts No Rating |
Hello, Is there an option in Revit to orient a view perpendicular to a work plane? For example, orthagonal floor plan views are perpendicular to the work planes defined by levels. If I creeate a work plane not orthagonal to x,y,z, is there a way to look at the work plane head on at 90 degrees?
You can rotate your Work Plane if you want and you have the option "View > Orient > By Plane"....
wonderful!
10 Posts No Rating |
I am trying to orient plan view parallel to working plane but the view>orient> shows only grey out options. Am I missing something? Thanks
8 Posts No Rating |
On this same topic... I was wondering if there is a way to "Orient to other side of plane" Revit is going to a perpendicular view, but it's not looking from the side we want to be on..... Do planes have side names?
save to central |
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
It will orientate to the side that its closest to at the time. Manually rotate the view around to the other side then orient again...
Regards,
Chris.
Perpendicular Elevation View, How?!? |
Tue, Apr 21, 2009 at 7:55:56 AM
Workplanes |
Wed, Jan 19, 2005 at 6:45:58 PM
building a physical model from a revit file |
Wed, May 9, 2007 at 9:31:57 PM
screen freeze |
Sat, Sep 18, 2010 at 8:14:13 PM
Orient a light to an angle Mass Plane in Revit 2010 |
Tue, Nov 24, 2009 at 10:32:25 AM
Members: | 2022290 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
