102 Users Online (101 Members):
Forums >> Revit Building >> Technical Support >> Custom Curtainwall Mullion Pattern help
4 Posts No Rating |
Is there a way to rotate a single horizontal mullion in elevation? So if the vertical mullions are vertical but the horizontal mullions are not horizontal but forming something of a zigzag pattern? Racking my brain . . .
Like what??? pictures please, also in the properties of the mullion you have the "Angle" parameter to rotate that mullion but i don't know if thisi is what you want...
4 Posts No Rating |
Basically a pattern in elevation that looks something like Charlie Brown's t-shirt. Just imagine vertical mullions at the peaks and/or valleys.
Like this????
4 Posts No Rating |
Not quite but that's further than I've gotten. Like that but without the breaks in the glass above and below. Vertical mullions above and below. So how did you do that? I can figure out angle in one direction but how did you angle in both directions? And then above and below, are those different types of mullions or did you erase mullions?
Yes just use the angle parameters for vertical & horizontal grids and adjust as necessary. I set mine to 60 & 30°. Then use add/remove individual grid segments to get rid of the lines where they are not needed. Unfortunately it will want to break it up occassionally still...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
17 Posts No Rating |
I know this thread hasn't been commented on in a while. Is there a way to create what Mr. Spot did (mullions with two angles) in addition to verticle mullions. Once you adjust the verticle and horizontal angles can you still add more mullions that are orthographic?
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing |
Mon, Jan 19, 2015 at 7:41:36 AM
coneptual massing curtainwall mullion issue |
Thu, Nov 5, 2009 at 11:54:41 AM
Adding a Single-segment mullion to a curved curtainwall |
Sat, Feb 9, 2008 at 8:00:15 AM
mullion ang transom not fitting well [ 1 2 ] |
Wed, Oct 9, 2013 at 11:42:10 PM
23
Converting curtainwall into wireframe |
Wed, Jun 13, 2012 at 2:08:44 PM
12
Members: | 2030582 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
