58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> component scale
Sun, Jun 19, 2005 at 6:16:24 PM | component scale
BIGMANJEE
is there any way to give a component a scale that is relative to a particular view, ie large at 1:100 but half the size at 1:50 i want to do some water reticualation drawings and i wish to indicate the pumps and valves at different scales on different drawings sheets. is there are way to do this.
Sun, Jun 19, 2005 at 6:41:48 PM | RE: component scale
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Only elements that will remain the same print scale in all views are symbols. In which case are 2D elements and would need to be placed in each view.
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:16 PM
Scale of Imported 3D Solid not working
Fri, May 16, 2008 at 1:28:56 PM
Scale Furniture
Fri, Nov 25, 2011 at 9:14:00 AM
Scale bar on sheet onto to display at certain scale
Wed, May 22, 2013 at 12:15:23 AM
Scale extrusions, solid, components
Sun, Oct 14, 2018 at 9:10:51 AM
Page generation time: 0.3263
