80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Slanted wall in section & sloped ceilings
Wed, Feb 18, 2009 at 12:49:09 PM | Slanted wall in section & sloped ceilings
mstanhall
Hi everybody.
 I'm new to Revitcity, but not to Revit. I'm trying to create a wall that slopes backward at a 10 degree angle in section. I have no idea how to modify an existing wall to do this. I know how to change the profile of a wall in elevation, but not in section. THe change profile button will not work when I try to do this, and neither will rotating the wall using the basic wall command.
Another issue I am having s sloped ceilings. I want to have a sloped soffit in one area of my building, but cannot, for the life of me, figure out how to make a ceiling slope. Help!
 Any help ould be greatly appreciated!
 Micah
Wed, Feb 18, 2009 at 1:15:03 PM | Slanted wall in section & sloped ceilings
ThatGuy
Hi
 Try using the create button under Moldeling there you can create an in place family using the solid geometry tool and give it parameters for the materials  be sure to have section views so you can see the prfile of the wall / ceiling you are creating.
(this should work for both of your problems)
Wed, Feb 18, 2009 at 1:50:03 PM | Slanted wall in section & sloped ceilings
tim123
4 Stars: 19 Votes
If you edit the ceiling there is a define slope function when you highlight  a boundary line.
Wed, Feb 18, 2009 at 2:10:45 PM | Slanted wall in section & sloped ceilings
4 Stars: 202 Votes
HI, see this: http://screencast.com/t/oii5MuEvnxJ
I make this video a few weeks/month ago to other guy but this solve your problem with the wall
HELP! Curved Sloped wall with slanted top
Sat, Jul 26, 2008 at 9:16:30 PM
12
section in slanted wall
Mon, Mar 4, 2013 at 3:12:21 AM
How to make slanted/sloped glass panel?
Wed, May 24, 2006 at 1:46:37 AM
Sloped Ceilings
Thu, Jan 23, 2014 at 4:54:41 PM
14
Slanted wall
Wed, Sep 12, 2012 at 11:59:39 AM
Page generation time: 2.9317
