Forums >> Revit Building >> Technical Support >> Raster Image Draw Order
Wed, Feb 18, 2009 at 10:40:48 AM | Raster Image Draw Order
CraigEngland
Hi, I have a raster image of a floor plan that is blocking out the Area's I have drawn so that you cannot see the colour of the Area Plan. How do I fix this so you can see the Area colours? I have tried sending the image to the back, but it still does not show.
Wed, Feb 18, 2009 at 11:21:53 AM | Raster Image Draw Order
caduk
try inserting the image on the level below + set up the view range, or try bringing it below the workplane your working on... if you can. hope this helps
Wed, Feb 18, 2009 at 1:16:00 PM | Raster Image Draw Order
CraigEngland
It ended up being that the Color Scheme within the View Properties had to be displayed in the foreground.
Thanks.
Raster Image display
Fri, Oct 10, 2008 at 6:08:26 AM
Raster Image
Fri, Jul 31, 2009 at 8:24:24 AM
draw order
Fri, Jul 21, 2006 at 3:19:43 AM
PDF Raster image as a super imposed backgroud
Sun, Nov 7, 2010 at 8:46:58 PM
Draw order furniture/walls
Thu, Mar 30, 2017 at 6:51:28 AM
Page generation time: 0.5329
