52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> hollow core planks
Wed, Feb 18, 2009 at 10:06:48 AM | hollow core planks
voglerb
i'm working on my first Revit Project.  A pre-cast concrete structure.  i'm having trouble with my hollow core planks running thru my pre-cast wall panels at my stair towers.  My walls run from the basement level up to the 3rd floor.  i've attached a angle to the wall panel to support the H.C. planks.  The planks run over the angle and thru the wall to the pre-cast beam around the exterior.  i'm was able to cope the planks around the pre-cast columns.
how do i keep them from running thru my wall panel and how do you cope a H.C. plank around the corner of the wall?
Thanks in advance
Tue, Mar 3, 2009 at 8:31:32 AM | hollow core planks
JACMD
you can draw the planks longer than they actually need to be, draw a reference plane at the face of the wall and then use the cut geometry tool to cut the planks at the desired angle..
Thu, Aug 13, 2009 at 2:01:05 PM | hollow core planks
allstardrafter
JACMD,
I tired the cut geometry idea, and worked great in one direction, but what if I need to to cut the plank in two directions? What I've got, and I think this is what voglerb is asking also, is how to I cut a hollow core plank around a corner? My planks are bearing on an exterior wall, and the wall jogs in and out, there are several instances where the wall jogs out right in the middle of a plank. I need to cope the plank so that half of it bears on the wall at 20' of span, and the other half spans out to 24'.
Is there a way that I can select two reference planes at same time, to use for my cut geometry?
Fri, Aug 14, 2009 at 6:43:06 AM | hollow core planks
vivhowe
Use Modelling - Opening - Opening by face
Select the face - draw the shape you want to remove - Finish sketch
Mon, Aug 17, 2009 at 4:09:07 PM | hollow core planks
allstardrafter
Thanks vivhowe!
Modelling an opening by face worked great. That's exactly what I needed to do!
Hollow Core Planks Modeled as Slabs Instead of Beams.
Mon, Feb 8, 2010 at 4:06:48 PM
Hollow Core Block Wall
Wed, Aug 13, 2008 at 7:53:37 PM
Trimming Precast-Hollow Core Slabs
Wed, Jun 3, 2009 at 10:52:21 AM
hollow mullions
Thu, Sep 4, 2008 at 5:46:00 AM
Timber Planks as wall
Thu, Jul 25, 2013 at 8:11:07 AM
Page generation time: 0.2613
