37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window Sill Returns?
Wed, Feb 18, 2009 at 9:51:56 AM | Window Sill Returns?
doubleclick
I'm trying to work through some tutorials on window families. I'm having trouble figuring out the head and sill returns though. If I specify a solid sweep, it forces me to pick the edge of the cut opening. . . this is not going to help because the ends of the sill need a profile too, not just the front.
If I was working in SketchUp, I would draw a line from the corner of the window opening out 4.5" from the wall, then parallel to the opening and then another 4.5" back to the other corner of the opening. I would then set my profile and use the followme tool to have the profile chase it around.
Either way, how do I make the profile sweep return?
Product name: AutoCAD Revit Architecture Suite 2009Product version: 2009.0.0Product service pack: Web Update 3 Service Pack
Wed, Feb 18, 2009 at 10:30:55 AM | Window Sill Returns?
tim123
4 Stars: 19 Votes
Draw the sweep path in plan view.
Wed, Feb 18, 2009 at 10:58:57 AM | Window Sill Returns?
doubleclick
Oh bother! I couldn't figure out why it wouldn't let me before. Apparently you have to start the sketch mode in that view. I was starting from elevation or 3D. Many thanks!
Window with angled sill
Fri, Nov 16, 2012 at 10:49:57 AM
window sills
Sun, Jun 18, 2006 at 5:16:17 PM
Sloped interior window sill in wall
Tue, Feb 14, 2012 at 3:30:26 PM
Window Schedule - Jamb, Head, Sill
Wed, Aug 7, 2013 at 4:06:57 PM
14
SLOPING CAST STONE WINDOW SILL APPLICATION
Thu, Feb 28, 2013 at 8:38:42 AM
Page generation time: 0.3454
