84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> trixy windows
Wed, Feb 18, 2009 at 1:33:52 AM | trixy windows
dnicholson
Hi guys,  the one thing that i seem to always have trouble with is windows.
I am using all downloaded windows as i cannot yet make my own families very well (booked on a course next month)
this particular issue is bugging me at the moment and thought id ask for help.
So im using this window and the front of the frame goes into a wall flush with the front face instead of over the cavity.
ive messed around with the window family (moved it all back into the wall and amended some profiles to suit) and that seems to have solved the problem in the 3D view but as you can see on the attachment the plan view is rubbish. any ideas how to fix this and bring the frame in so that it can sit over the cavity without having to have a really deep frame that is in the wrong location.  thanks.
Wed, Feb 18, 2009 at 4:09:16 AM | trixy windows
tim123
4 Stars: 19 Votes
If I understand your problem correctly, you need the frame to cover the cavity and not extend to the outside face of the wall.  There is a constraint that is defining this that you need to find and unlock.  You could also try and draw a ref plane where you want the frame to end, with a depth parameter.  Align and lock the frame to this plane.
My Windows are not in my Windows Tab
Tue, Dec 15, 2009 at 7:02:39 AM
Does Revit 2009/2010 work properly to on Windows 7
Thu, Jun 3, 2010 at 4:25:05 AM
12
rendering windows in 2009
Wed, Aug 27, 2008 at 8:35:02 AM
Windows 7 and Revit 2010
Thu, Nov 18, 2010 at 11:54:10 AM
Need Rakehead windows......
Wed, Apr 22, 2009 at 1:15:13 PM
Page generation time: 4.1444
