Forums >> Revit Building >> Technical Support >> Model Text Width Factor??
Is there a way to change the width factor in Model text? Or adjust freely (aka Free transform)? Thanks, Lorne
Denver, CO
Revit Architecture |
Select the model text, go to properties in options bar, "DEPTH", I think this is what you mean with "Width Factor"....
I think that you can only use standard fonts for model text. You cannot adjust the width.
" Select the model text, go to properties in options bar, "DEPTH", I think this is what you mean with "Width Factor".... " No I needed Width Factor. I need to make the text more narrow. You can change the width factor in any typical 2D text. I guess not 3D as Tim said. Thanks, Lorne
Denver, CO
Text Box Width Factor Masking Error |
Wed, Mar 18, 2015 at 2:33:51 PM
Can you adjust the text width for dimensions? |
Thu, Oct 27, 2005 at 5:20:01 PM
text width factor for dimensions |
Thu, Apr 20, 2006 at 7:44:22 AM
Width factor as a parameter |
Thu, Oct 30, 2014 at 7:23:30 AM
Text line height spacing - can it be changed like the width? |
Thu, Dec 12, 2019 at 4:29:10 AM
Members: | 2100330 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
