Forums >> Revit Building >> Technical Support >> Rotating the text in dimensions
![3 Stars: 2 Votes](/images/stars_3.gif) |
Is there a way to override the text in dimensions so I can rotate just the text? I have a rotated viewport on a few sheets. I have already rotated the other text in the view, but there is no "keep readable" button to override in the dimensions... help!
Cheryl Nelson Randall W. Hein Architects |
Look at your text setup options under settings/annotations/dimensions
Ok.... I did... still nothing that will essentially let me place text upside down in a view, but that will look correct on the sheet. The only options are up left, up right, right up, and left up.... I guess I need an option that says down.
I don't understand. Revit automatically will rotate dimensions when you rotate a view to place it on a sheet. Did you rotate your sheet instead? If so - don't do that.
No I rotated the viewport, not the sheet itself. The viewport is rotated 90 deg. counter clockwise to fit on the sheet better. When I do that the text in some dimensions looks like its upside down. I need to rotate the text, but Revit is fighting it.
You activated the view - picked the crop window and rotated that? Correct?
No. I placed the view on the sheet. Selected the vieport, and in the properties of that viewport, I picked rotate counterclockwise 90 deg.
Try the method I described....
Sorry for my ignorance, and thank you for your patience.. I got it.
Adding Text Below Dimensions |
Sat, Mar 3, 2007 at 10:55:04 AM
11
Rotating Family Text |
Wed, May 7, 2014 at 5:04:06 PM
View Rotation - Dimension text |
Thu, Jul 21, 2016 at 12:06:48 AM
Text width for dimensions... |
Tue, Aug 7, 2007 at 7:55:42 AM
TEXT AND DIMENSIONS |
Tue, Sep 28, 2004 at 12:49:38 AM
