57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing View Range to a lower level?
Mon, Feb 16, 2009 at 8:44:27 AM | Changing View Range to a lower level?
jbaysinger
3 Stars: 4 Votes
Hello there, I am using Revit Arch and Struct. 09.  I have a template made that we use for projects.  We are doing individual concrete pours with this template. When I made the template, I had a level set to 90' for my foundation level.  Then I duplicated that level for each individual wall pour with a bunch of filters added to the views.
Now, in my project I am working on, I left my foundation level at 90', and just added new levels below that, Down to level 56'.  So when I go to the individual wall pours and go to the view range, they are associated with level 90' and I need them down to level 56'.  But the drop down arrow will not let me go any level lower than 90'.  Is that because the individual wall pour views are associated with level 90?  I am stumped on what to do.  Any suggestions for me to be able to see at level 56' with the individual views I already have set up?  Thanks
Mon, Feb 16, 2009 at 9:46:46 PM | Changing View Range to a lower level?
shaun_kiwi
5 Stars: 2 Votes
Did you make each floor plan view new and associate it with each level you made or were they one view copied and doctored in view range.?
Shaun
Tue, Feb 17, 2009 at 7:25:00 AM | Changing View Range to a lower level?
jbaysinger
3 Stars: 4 Votes
Each of the individual views were duplicated from the original 90' foundation level and then cropped to the area of the building we are pouring.
Associated Level in View Range
Wed, Nov 12, 2008 at 8:36:23 AM
View Range or Cut Plane Settings for Split level and Cape style
Fri, Jul 6, 2012 at 8:19:54 AM
View Range
Fri, Mar 13, 2009 at 5:05:41 AM
View Range
Thu, Oct 24, 2013 at 2:37:43 PM
LOCKING LOWER LEVEL IN UNDERLAY
Tue, Mar 6, 2007 at 2:37:10 PM
Page generation time: 1.0903
