56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> installing revit on a netbook?
Sun, Feb 15, 2009 at 8:21:16 PM | installing revit on a netbook?
magellantech
I was attempting to install revit on a msi wind netbook 2 GB of memory. , Unfortunately the MSI wind has only 600 vertical lines of resolution vs the normal 700+.  When trying the installation the "next", "cancel" buttons were below the 600 lines of resolution, thus could not be seen.  There is no way to scroll down or reduce the size of the installation panel.  I've tried connecting it to a monitor, but only the 600- lines are reproduced and the the installation screen cannot be reduced in size.  Has anyone found a solution to this problem?  I'd love to be able to carry my revit loaded netbook on a job site.  Thanks.
Mon, Feb 16, 2009 at 6:43:30 AM | installing revit on a netbook?
qthdad
5 Stars: 2 Votes
1. Haven't tried this with an installer screen, but try this: Right-click on the application in the Windows Taskbar and select MOVE. Use your arrow keys to move the screen up and press ENTER.
2. Usually the TAB key will cycle through the buttons and fields. Sometimes you can also hit the 'N' key for Next. Depends on the installer software.
3. You could also use an installation packager to re-package into an automated install.
Mon, Feb 16, 2009 at 7:53:42 AM | installing revit on a netbook?
magellantech
 the right-clicking did nothing, as did trying the arrow keys.  Fortunately hitting the "n" does work, but since you cannot see the lower portion of the installation screen to view the options you have to intuitively know what the option are.  I'll chime back in, once the installation is completed.  Thanks
Mon, Feb 16, 2009 at 8:56:27 AM | installing revit on a netbook?
qthdad
5 Stars: 2 Votes
This is what I meant about Right-Click and Move. See attached image. Maybe the OS is different on the Netbook.
Now that I think about it though, if you have problems with the install window, it would lead me to think you'll have the same problem as far as screen size when trying to run Revit. Still, it would be interesting to try.
Problem installing Revit 2014
Sun, May 5, 2013 at 5:05:12 PM
Installing 8
Thu, May 12, 2005 at 10:34:21 PM
Can I change my default Imperial Style to Metric without re-installing?
Fri, Feb 19, 2010 at 6:56:31 AM
INstalling solar CCTv
Fri, Oct 12, 2012 at 2:16:18 PM
problem installing
Tue, Apr 19, 2011 at 3:23:12 AM
Page generation time: 3.3421
