Forums >> Revit Building >> Technical Support >> Interior Elevations appear transparent
7 Posts No Rating |
For some reason everytime I place an interior elevation it shows as partially wireframe (not showing every detail, just the immediate wall behind the wall I am looking at. Ive checked a thousand times and its set to hidden line. Anny ideas on how to fix this?
What flavor and version of Revit are you using? Do you have linked files?
Phase overide?
----------------------------------- Shaun |
7 Posts No Rating |
I am using Revit Architecture 2009. I do not have any phases as of yet and there are no graphic overrides. Thanks!
Where is the cutting plane? Wall construction? There are phases in use by default and a phase override have you gotten rid of these?
7 Posts No Rating |
Cutting plane is through the middle of the room, wall construction is solid, 2x4 wood stud w/ gyp both sides. All phases are showing, (default phases) thanks again
elevations have gone transparent |
Wed, Jun 6, 2012 at 6:02:05 PM
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:30 PM
interior elevations |
Wed, Apr 11, 2007 at 9:43:05 AM
Interior Elevations Referencing Detail Numbers |
Sat, Oct 13, 2007 at 11:04:40 AM
Interior Elevations |
Mon, Jan 23, 2006 at 5:42:43 AM
Members: | 2100928 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
