86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Light Source
Fri, Feb 13, 2009 at 2:26:25 PM | Light Source
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
I have seen threads about light sources (actual light coming out of the fixture) not rendering in recessed can light families becasue of ceiling etc, but has anyone had issues with it on standard hanging pendant lights? When I render the light is cast onto the objects in the room but the light fixtures remain black, as you can imagine, it looks a bit carzy silly with random light casting onto objects with no light source in sight!
I've a attached a quick render for reference
 Note: The pendant lights are between the clouds
Thanks!
Edited on: Fri, Feb 13, 2009 at 3:05:34 PM
cad.web.print
Thu, Feb 19, 2009 at 8:01:01 AM | Light Source
robinballew
robinballew Avatar
3 Stars: 4 Votes
I usually make part of the light family a bulb.. I assign a material "bulb" that makes it look it is giving off the light. I think it is under Glass materials.
BallewDesigns.com
Light Source in Revit - the dead horse
Thu, May 6, 2021 at 4:34:17 PM
13
Downlight with hidden light source
Sat, Nov 23, 2013 at 8:19:33 AM
Light source inside the light fixture
Fri, Feb 22, 2013 at 7:24:32 AM
rendering light source
Mon, Dec 19, 2011 at 3:50:41 PM
Issues with Light Source in Revit 2013
Wed, Jun 5, 2013 at 2:48:23 PM
Page generation time: 0.2740
