44 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> applying revit materials to imported sketchup geometry HELP!!?
Fri, Feb 13, 2009 at 1:06:44 PM | applying revit materials to imported sketchup geometry HELP!!?
billyjencks
I've created some relatively simple sketchup models to use as exterior cladding elements (precast frames, screens, and architectural articulation elements, etc...) and imported them to my revit model.
I created these by exporting the revit model into sketchup, drawing the components onto the existing revit frame, matching the component origins to the origin of the revit model, and the importing into revit using "origin to origin." The geometry is placed perfectly and looks great, except it all has the characteristic "sketchup tan" color and renders a flat grey. I have tried importing directly into the model, into a component (create in place), and into an in-place family, and I still can't figure out how to apply a different material. I've even changed the materials under settings>>object styles>>imported objects and this has no effect.
 somebody please? any ideas??
 I also created an external family and tried to assign a material perameter but i don't know how to get this generic model family placed in my building model... help on that?
 cheers
Fri, Feb 13, 2009 at 1:22:41 PM | applying revit materials to imported sketchup geometry HELP!!?
billyjencks
figured it out... went back to look at aalmerico's post again and realized that you can expand the imported objects catagories, and have to apply materials to their subcatagories to get it to work. Thanks! awesome tool
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:09 AM
Import model from Sketchup to Revit- Materials not showing up in rendering
Wed, Mar 17, 2010 at 1:27:25 PM
applying revit materials into imported sketchup file in revit family
Sat, Dec 10, 2011 at 6:52:34 AM
PROBLEM with assigning materials in imported components from Sketchup
Sun, Oct 23, 2011 at 5:01:41 AM
Sketchup to Revit
Fri, Nov 19, 2010 at 3:44:54 AM
Page generation time: 2.0129
