56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> moving object with an array
Fri, Feb 13, 2009 at 11:19:52 AM | moving object with an array
jhendershot
I am building a shelf system with standards and brackets. I want to be able to use the 2nd array option so the user can input the number of shelfs and have them populate at a specified distance between. I want to show the standard at a distance above the last shelf, so say i have 3 shelfs the standard shows 6" above that, If i put in 6 shelfs the standard will stretch 6" above the 6th shelf. currently if i lock the ref line 6" above the last object in the array it just stays there when the array is increased. is there a way, formula or otherwise, to get the ref plane to follow the last in the array?
 thanks.
 j.
Fri, Feb 13, 2009 at 11:46:09 AM | moving object with an array
jhendershot
i just noticed as well that i can not control the dimensions of an object within an array. is this correct? can you not control the first object in an array and have the rest of the array follow suit?
Changing Dimension object in Array
Thu, Jul 27, 2017 at 6:05:06 AM
Array association
Tue, Nov 11, 2008 at 9:17:32 AM
Array along a curved path
Tue, Nov 11, 2014 at 9:11:46 AM
Array association and relocation - please help
Mon, Jun 1, 2009 at 10:28:51 AM
Elevation Problems
Wed, Mar 26, 2008 at 1:40:01 PM
Page generation time: 0.4248
