79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Can linked RVTs NOT be selected?
3 Posts No Rating |
I know you can pin a linked RVT to restrict it's movement, but can you set it up so that you can still see it, but it doesn't highlight if you accidentally select it? Matt W
With Revit, you really have to pay attention to window and crossing selections. Given dpth of view, you may be picking something on the otherside of the wall you can see through. Always use your filter when selecting!
3 Posts No Rating |
So basically that's a big, fat NO. Which is pretty much what I was expecting - I just wanted to double-check. Thanks.
I think this just goes along with developing good REVIT habits. Looking at your filter after selecting with windows or crossing is a MUST ... with individual selections, you always want to use your tab and see what you are selecting in the lower left corner.
3 Posts No Rating |
I'm at the beginning of the "learning stage" with MEP, so now's the time to develop those good habits! Thanks!
Can't select the linked model |
Mon, Aug 4, 2014 at 1:06:26 PM
Aligned to selected levels. |
Sun, Jul 17, 2016 at 4:49:50 PM
13
Unable to PICK lines from linked file |
Thu, Aug 21, 2014 at 8:47:06 AM
Model lines in LINKED files |
Fri, Jul 19, 2013 at 9:48:35 AM
Refreshing linked AutoCad drawings |
Fri, Jan 30, 2009 at 11:48:50 AM
Members: | 2021228 | Objects: | 22965 | Forum Posts: | 152193 | Job Listings: | 3 |
