71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> tunnel under a site
Fri, Feb 13, 2009 at 2:23:53 AM | tunnel under a site
Bansri
hi,
i know, it's a strange question, but i need to get a tunnel passing under the site... how can i do that??
any ideas??
Fri, Feb 13, 2009 at 10:01:31 AM | tunnel under a site
quinn
Just make sure you have an elevation set for the tunnel level or offset your tunnel walls and pad etc below the first floor level.  I would use the pad option in the site bar to cut the earth out you can set the pad to 1/16" thickness or whatever you want but it will cut the earth for you.  Other than that the rest is up to you how you want to do it. Walls, Massing with walls applied to face, etc.
How to construct a freestanding tunnel?
Thu, Nov 24, 2011 at 3:02:47 AM
Tunnel in toposurface
Wed, Oct 27, 2010 at 5:36:50 PM
Create tunnel within toposurface
Mon, Jul 7, 2014 at 8:58:05 AM
I am trying to model Train Tunnel?
Thu, Jul 14, 2011 at 12:19:13 PM
Sun Tunnel
Thu, Dec 22, 2011 at 3:52:53 PM
Page generation time: 1.8087
