52 Users Online (51 Members):
Forums >> Revit Structure >> Technical Support >> Adding Graphics into a schedule
15 Posts No Rating |
Is it possible to add any graphics ... detail, symbol ... anything into a schedule? I have been able to add a parameter where is asks for a detail, but I cannot get that to go into a schedule ... Basically I want to have a pier schedule where is gives the pier dimensions, reinforcing, and a general configuration of the reinforcing. It is the general configuration that I am trying to use as a graphic (such as a 4 vert, 6 vert with ties, 8 vert with other config of ties and so on.) Thanks Bill
no...
Yes, and No. You can make it 'look' like there are graphic sections and callouts on a schedule, but you cannot add these elements directly within a schedule. After I create a column schedule and place it on a sheet, I create a drafting view and place it directly over top of the column schedule. Within this drafting view, I add my callout and section bubbles along with any other information that I see fit to add. I do all of this work while I am on the sheet view so I can see the column schedule underneath and add elements accordingly. Hope this helps. See the attached PDF file:
Graphics and Schedules |
Wed, Jun 17, 2009 at 2:22:33 PM
Adding a shade to the Total line (footer) of a schedule Revit 2022 (23 or 24) |
Fri, Oct 27, 2023 at 8:53:27 PM
Adding Room Names to Door Schedule |
Sun, Aug 21, 2016 at 11:03:06 AM
Adding Phase Created to Room Schedule |
Fri, Sep 9, 2016 at 11:29:02 AM
Adding Items to a Schedule |
Tue, Feb 26, 2008 at 9:47:18 AM
Members: | 2030869 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
