29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> curtain wall mullions parameters
Thu, Feb 12, 2009 at 8:36:48 AM | curtain wall mullions parameters
paulykustomz
paulykustomz Avatar
is there a way to create a parameter for a curtain wall mullion to calculate a number of screws per linear foot of mullions? example 1 screw every 6 inches of mullion? and is it possible to bring that to a schedule?
other question is is there a way to create a restraint or parameter for the mullions to not exceed a certain length? like maximum 8 ft? because we have a project with strict standards.
thanks in advance
Fri, Feb 13, 2009 at 2:28:00 PM | curtain wall mullions parameters
4 Stars: 204 Votes
I don't think so, if i'm wrong i also glad to know ....
Thu, Mar 5, 2009 at 2:52:59 PM | curtain wall mullions parameters
paulykustomz
paulykustomz Avatar
hey typhoon,
I figured how to calculate for the screws. I just used a calculated valuein theschedule. length of each mullion divided by the screw spacing= number of screws
the other problem I had was calculating the total length of vertical mullions. this was a quick fix it actually came to me in a dream as stupid as that sounds. all you have to do is create a MULLION GRID parameter. you select all the mullions in on vertical row and assign them a grid name. then in the schedule all you have to do is group them by mullion grid and voila the total lengths of your vertical mullions.
as for calculating the maximum lengths of  you take the total run of the vertical mullion grid and use a calculated value. total MULLION GRID length divided by maximum allowable length = how many pices you need.
hope this helps someone
Edited on: Thu, Mar 5, 2009 at 2:54:59 PM
Edited on: Thu, Mar 5, 2009 at 3:01:19 PM
Thu, Mar 5, 2009 at 5:11:08 PM | curtain wall mullions parameters
eldados
eldados Avatar
4.5 Stars: 8 Votes
nice one Paul Smile
almost anything can be calculated with schedule
Integrator
KarelCAD
Arched Curtain Wall Arched Mullions
Wed, Jan 22, 2020 at 2:13:08 AM
Curtain wall with splayed mullions
Tue, May 10, 2016 at 2:05:31 PM
Curtain wall mullions
Fri, Jan 11, 2008 at 9:22:15 AM
Miter Curtain Wall Border Mullions
Wed, Apr 21, 2010 at 3:04:57 PM
Angled and Straight Curtain Wall Mullions
Mon, Feb 27, 2012 at 12:19:11 PM
Page generation time: 2.3173
