48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> New Sub-Category for Different Sections
Tue, Feb 10, 2009 at 7:11:48 PM | New Sub-Category for Different Sections
ttiefenbach
ttiefenbach Avatar
3 Stars: 2 Votes
I've created a section tag for our glazing elevations so that we can double click the glazing tag and pull up the elevation.  The only issue is theis section mark will show up in all the wall sections and elevations.  I thought if I could create a new section category then I could hide that sub-category in my other views.
Is this possible?
Sun, Feb 22, 2009 at 12:38:00 PM | New Sub-Category for Different Sections
robinballew
robinballew Avatar
3 Stars: 4 Votes
you can hide by "element" not Subcategory..
BallewDesigns.com
Mon, Feb 23, 2009 at 3:46:22 PM | New Sub-Category for Different Sections
jejonker
jejonker Avatar
Have tried it but it doesn't seems to work. Altough you can create a new anotation object categorie (place it under Generic Annotations) in the Section tag Family, you cannot select this categorie under subcategory when changing the element properties.
Sorry.
Can we create our own category?
Mon, Nov 23, 2009 at 7:48:27 AM
Problem with wall sweep show on wrong sections
Wed, Mar 22, 2006 at 5:37:33 AM
Baluster category/sub category
Tue, Nov 19, 2013 at 9:43:57 PM
Sections Referencing the drawing you want. Help Cheat!
Fri, Feb 25, 2011 at 11:22:06 AM
Settings by category
Wed, Aug 4, 2010 at 8:36:27 AM
Page generation time: 1.6586
