Forums >> Revit Building >> Technical Support >> Looking for someone to help with a waterslide
59 Posts No Rating |
HI, I am having problems making a waterslide. I have read some of the comments made by others for it but still find it impossible to do. Does anybody have any suggestions on how i can do this. Kind of like a step by step way that would be easier.
----------------------------------- JD |
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
Did you try the ramp tool? Do you have an examle of what you need?
----------------------------------- BallewDesigns.com |
HI so i haven't tried to use the ramp tool because i don't know how to use it to make a slide. i have an example of the waterslide that runs into a runout lane. and it would start at 6868m above ground. any ideas would be greatly appreciated. thanks
k my example doesn't seem to be loading
k ignore the kobe wall paper but the slide is on the right side
here it is ignore the kobe wallpaper haha its the one on the right had to put it on the document cuz the size was to big
![4 Stars: 12 Votes](/images/stars_4.gif) |
ok i had the very same before, if i'm write it is a tube twisting that you are looking for, i will have to look in my archive , but i think the best solution is a giant hand rail railing on an invisible spiral stairs. of course you could make it in autocad, rhino, inventor, 3ds max etc. its late so i'm off home for the night but i will try to find the one i made before and post it for you.
ok thanks
