50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ground lines
Tue, Feb 10, 2009 at 3:57:22 PM | Ground lines
agcaddes
just wondering how people represent the existing ground line on elevations to show what the ground was like before the building was put on the surface and levels amended to suit.
Tue, Feb 10, 2009 at 4:12:00 PM | Ground lines
If you have your site bulit with graded regions/pads - you should be able to show it automatically.
Tue, Feb 10, 2009 at 4:46:44 PM | Ground lines
agcaddes
Thank you very much, just what I was after. Only a new user and have found this site to be very helpful.
Tue, Aug 4, 2009 at 12:14:51 PM | Ground lines
Tim79
I'm trying to do exactly this at the moment with great difficulty. The problem appears to be related to phasing and graphical substitutions, but no matter how many parameters I try, I can't get the original site toposurface (existing) to show a dotted line in elevation without blocking out the portion of my facade which is below the line. Any thoughts anyone???
Another point of complication is that my toposurface is in a linked file. Not sure how/if this would have an effect.
Sun, Jun 12, 2011 at 7:52:13 AM | Ground lines
RNLRNL
Did anyone find a solution to this - I am having the same problem - the existing ground line is hiding everything below it in section on the proposed section drawings
Mon, Jun 13, 2011 at 5:00:12 AM | Ground lines
mcantwell
mcantwell Avatar
http://www.revitcity.com/forums.php?action=viewthread&thread_id=5515
Mon, Jun 13, 2011 at 1:32:57 PM | Ground lines
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Either cut the topo around the foundations of the building, or use a pad, or represent the ground with filled regions.  For our sections we use a minimal gray filled region against basement walls, arcing up to ground level.  it takes about 10 minutes to give the impression of ground plane across all sections, and looks better than tooling with visibility settings, and still having large swaths of earth hatch on the sheets.
Rendering Ground Planes showing up when i dont want them to
Wed, May 10, 2006 at 7:14:44 AM
how to see upper levels dash lines at the ground floor?
Thu, Dec 24, 2009 at 2:26:33 AM
Faint lines showing from ground floor on first floor
Sat, Mar 10, 2012 at 4:40:34 PM
NATURAL GROUND LINES v's FGL
Thu, Mar 26, 2009 at 6:56:40 AM
Rendering - Changing Ht of Ground plane does not 'stick'
Thu, Mar 10, 2005 at 4:35:09 PM
Page generation time: 0.4750
