50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> REVIT vs. Vectorworks and SHOP DRAWINGS
Tue, Feb 10, 2009 at 3:26:27 PM | REVIT vs. Vectorworks and SHOP DRAWINGS
takagi
REVIT 9.1
Hi!
My firm is collaborating with another firm that uses Vectorworks (3D).  I haven't used that program for YEARS and am an AVID REVIT worshipper (years yers of using).
They will consider switching over, but they do not understand the power of Revit and I don't understand what vectorworks does anymore.  Anyone have any experience with both (current versions) that can help me convince them and explain the major advantages.  They seem to think Vectorworks does what Revit does, but I do not see how that is possible???
PLUS
I am also working with a modular housing company that needs a fast translation from my Revit drawings (mostly housing with 4-200 units).  These are WOOD framed standard construction prefab.  I've read the Autodesk university "Modeling Wood Structures" paper and peoples posts on "faking" a wall (using railings etc) but the work arounds will not give me material counts and calcs etc...
I'd like to stay with one program as much as possible but do not think building all the wood framing in Revit is very efficient?  Anybody have any ideas and or experience with this dilemma?
PLEASE ADVISE and you will have a wonderful life!
 THANKS!!
Taeko
Tue, Feb 10, 2009 at 5:59:45 PM | REVIT vs. Vectorworks and SHOP DRAWINGS
robinballew
robinballew Avatar
3 Stars: 4 Votes
I don't know anything about Vector Works... As far as the wood frame construction I would use the Beam System tool and build the top and bottom plates into the wall. You can then get all the material takeoff.. However, I have a lot of residential experiance and find little use in diagraming walls this way. Let me know if you need more detail or need more help.
BallewDesigns.com
Tue, Feb 10, 2009 at 8:55:40 PM | REVIT vs. Vectorworks and SHOP DRAWINGS
takagi
In general I would never need to draw the framing "shop drawings" since I do large residential projects, but this is particular to the fabrication / pre-fab world that needs quick translation.
Any other ideas out there??
THanks
tt
Using Revit MEP to make ductwork shop drawings
Wed, Jun 15, 2011 at 9:52:03 PM
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Sun, Feb 24, 2013 at 1:00:01 PM
Importing 3d geometry from Vectorworks
Wed, Apr 27, 2005 at 11:01:03 AM
Precast Concrete Shop Drawings
Fri, Apr 10, 2020 at 2:08:55 AM
Any luck with making Mechanical shop drawings from Revit?
Fri, Dec 17, 2010 at 11:37:05 AM
Page generation time: 3.7619
