87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> section tag in legend view
Tue, Jun 14, 2005 at 8:14:43 AM | section tag in legend view
Chymos
Using Revit 8.0. We have a legend done with window elevations and we would like to tag some head, jamb, and sill details on these window elevations. We already have the details drawn in drafting views and all we need are section marks that reference these details. Apparently, we cannot insert intelligent section tags in a legend view (why not is completely beyond comprehension). The only work around we have found is creating our own UN-intelligent tags that will need to be manually updated when anything changes. Does anyone else have any better suggestions?
Tue, Jun 14, 2005 at 11:23:49 PM | RE: section tag in legend view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm that is a dilemma... Haven't come across that before, bit in reality legend views to do not represent any Actual situation in particular all they show is the family and the views are merely 2D representations. Two options i would consider would be use the plan view legend components to detail jambs etc. OR What we used to do (prior to legends) to create actual elevations and sections of the windows and doors in the model. Which is probably more correct as i'd imagine your jambs may differ depending on the host wall type... which isn't reflected in a legend component... HTH.
Wed, Jun 15, 2005 at 9:00:29 AM | RE: section tag in legend view
Chymos
Your second option is exactly what we used to do before legends, but legends seemed to be just the ticket for what we desired to create. We typically use schedules for doors, but tag windows in plan by type. Ideally, it would be nice to insert a section tag in the legend view that would reference the detail view we already have drawn. That way, just like in regular views where you can insert section tags, the tag would be intelligent and number itself once the detail view was placed on a sheet. Maybe this is one for the wishlist...
Wed, Jun 15, 2005 at 9:00:23 PM | RE: section tag in legend view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Agreed. add to the wishlist. Maybe if we could only reference to drafting views in a legend view that would prevent any confusion...?? Factory?
Tue, May 2, 2017 at 4:00:05 PM | section tag in legend view
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I too am trying to get a view reference detail on our door frame legend.  Not sure why Revit 2017 can't do this when this was an issue 12 years ago!!!
Anyone have any work arounds since?  We used to use the future scheduling phase to have elevations of our door types, however now we use legends and this issue has come up.
Thanks,
Lorne
Denver, CO
Revit Architecture
wishlist - section tag in legend view
Thu, Mar 13, 2008 at 2:52:37 PM
Create Detail Section without tag?
Thu, May 22, 2008 at 2:38:51 PM
Elevation tag missing in Symbol Legend
Tue, Nov 21, 2006 at 1:18:44 PM
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:16 PM
Window Tag
Wed, Jun 10, 2009 at 12:30:15 PM
Page generation time: 1.6542
