Forums >> Revit Building >> Technical Support >> SLANT WALLS?
2 Posts No Rating |
my exterior wall is slated.... how do you make this... think of a diamond shape or a funnel. it getts bigger the higher it goes... how do you model this... i'm totally new to this program , but i've figured out alot on my own, but not this technical stuf... please help meee.. i have a midreview weds....... thanks anything would be good.
If i understand you right - the shape of the wall when viewed square on is shaped like a diamond or funnel? if this is the case then try editing the profile... click on the wall, select 'edit profile' from the option bar, then sketch the outline as you'd like to see it and finish the sketch. Good luck with your review!
One way is to create a mass and apply wall finishes to the surfaces. You can then delete the mass. See image.
25 Posts No Rating |
hi guys i really need help biig time i cannot slant any of my walls on revit,i am new to revit architecture and am working on a project which requires slanted walls, i have tried creating mass and sweep blends and everything but it keeps on giving me an error i would request for a detailed procedure into creating one it would be of great help and its quite urgent..... thanking in adnvance
Hi, see the video: http://www.megaupload.com/?d=Z8G86YNE
hi i managed to slant the walls it was a great progress thanks but now i am stuck with the mass not takin in any material, i want this wall i have created to be a curtain wall how can i do this please let me know, i also have another question i am designing an auditorium so it has that theatre like seating so all the seats are on a diff level goin down something liek what when we go to the cinema i wanted tro create this please advice and thanking you... very urgent
Joining Roofs with different slant angles |
Fri, Apr 19, 2013 at 10:19:06 AM
Slanted walls in 3d [ 1 2 ] |
Fri, Feb 23, 2018 at 10:05:17 AM
15
slant walls |
Wed, Apr 6, 2005 at 1:45:37 AM
joint slant and vertical mullion |
Tue, Oct 23, 2012 at 9:05:44 PM
Slanted opening through wall |
Fri, Feb 26, 2010 at 4:51:28 PM
Members: | 2116466 | Objects: | 23196 | Forum Posts: | 152302 | Job Listings: | 3 |
