Forums >> Workflow & Implementation >> API & Third Party Apps >> Revit MEP 2009-VSTA error
22 Posts No Rating |
Revit VSTA error Posted: Feb 9, 2009 6:19 PM I installed Revit VSTA (Revit MEP 2009), opened it once, and now, every time I open Revit, I get an error message "An active session of Revit MEP is already using Visula Studio Tools for Applications. VSTA can only link to one Revit session per installation, so it vill be disabled for this session of Revit" And when I open Revit, the External commands-Macros are grayed out.I don't have any other session of Revit open, it's only one installation of Revit MEP and VSTA.Any solution for this problem?
Reboot doesn't work?
Not just reboot. I uninstalled and reinstalled VSTA, it doesn't work
Sorry, haven't seen this problem. Hopefully someone else will chime in. My only other thoughts are to make sure you have Windows up-to-date and then reload both Revit and VSTA.
I got it. The VSTA program still running after you close Revit session. I stop it from Task Manager (vsta.exe), and start Revit normally. My mistake was-after reboot I openned Revit, than close it, and open again, and got the VSTA error. I hope, the Autodesk Revit design team will fix this bug.
revit structure 2009 VSTA (I CANT GET IT WORK) |
Thu, Apr 24, 2008 at 2:04:06 AM
VSTA doesn't work |
Sun, Apr 5, 2009 at 8:40:43 AM
VSTA Q's |
Mon, Jul 21, 2008 at 5:07:41 PM
Revit error messages |
Wed, Jan 21, 2009 at 6:41:48 PM
Revit MEP 2012 View Port Error with Linked views |
Tue, Sep 4, 2012 at 11:50:45 AM
Members: | 2115710 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
