48 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> "Furniture tag"
14 Posts No Rating |
Hi!
I have a closet-familj and and want to have a letter in it foe each type of closet.
for exampel a G for Garderobb and a L för linneskåp. It has a label "Show" and a label for angel.
When i put the closet in side my draft I want to be able to
a: Change the letter
b: Chnage the angeleav letter
c: The letter shuld always be att the center of the closet.
But it would be better if some how the letter was always horizontal regards what angle the closet have.
Any proposals??
7 Posts No Rating |
You will need to create a general annotation family and insert it your furniture family. Use a shared parameters for you letters.
Placement will be inside the furniture family and for reading, check under settings for keep readable
You could also set it up via shared parameters and tags.
Add shared parameters to your closet family for the information you want to report then create a tag for the category you are using for the closet (casework?) that reports these shared parameters then tag in the project.
This is a fairly advanced process to setup, but is the best way to achieve what your after.
HTH.
Cant Tag Furniture. keeps asking to load furniture tag |
Sun, Dec 9, 2012 at 6:59:11 PM
"Tag by category" of Architectural Column in Plan |
Thu, Apr 16, 2009 at 2:45:20 PM
Furniture Tags & Sketchup Furniture Components |
Fri, Dec 4, 2015 at 9:35:33 PM
tagging by "family name" and "family type" |
Mon, Jun 1, 2009 at 8:54:54 PM
Help. I forgot how I "turned off" the room tags. |
Tue, Oct 8, 2013 at 7:18:18 AM
11
Members: | 2057494 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
