50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> plan region/view range window
![RainaMc Avatar](user_avatar/72958.jpg)
126 Posts No Rating |
Hello, Working in 2008 and having a prolbem with plan region and getting a window to show up. See attached floor plan with plan region and the elevation. What do I set the view range to on the plan region to get window to show up in second floor plan. It is currently set with the top: second fl. 9' cut: second fl. 4' bottom: second fl. 0' level: second fl. 0' These are the current view range settings however it seems no mater what i change it to it will not show up. Does anyone have a answer? View ranges are driving me crazy. Thanks everyone.
Turn on your plan region in plan so that we can see that & pull up your plan region's properties ... then do a screen shot of that ... better than pdf's. Might look at screenhunter - it's free.
Plan Region and View Range issue |
Tue, Sep 26, 2017 at 7:27:30 AM
View Range ignore Plan Region in linked files |
Thu, Sep 15, 2016 at 7:34:58 AM
View Range/Plan Region Visibility Controls in RCP |
Wed, Feb 1, 2012 at 11:20:32 AM
Understanding Plan Region |
Fri, Aug 15, 2014 at 11:49:48 AM
Plan cuts incorrectly at windows despite correct view range |
Thu, Aug 6, 2009 at 9:12:23 PM
Members: | 2022246 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
