56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> CURTAIN WALLS ADDING DETAIL OR PROFILES?
Mon, Feb 9, 2009 at 3:11:17 PM | CURTAIN WALLS ADDING DETAIL OR PROFILES?
paulykustomz
paulykustomz Avatar
THIS IS MY PROBLEM. I'M TRYING TO CREATE MY OWN CURTAIN WALL SYSTEM. BUT THE PROBLEM IS I WANT TO BE ABLE TO SEE A DETAIL WHEN I CUT IT IN SECTION. I HAVE ATTACHED A FAMILY I FOUND. IF YOU CUT IT IN SECTION YOU SEE THE DETAIL DRAFTING VIEW BUT IF YOU CUT IT WITH A SECTION BOX IN 3D YOU CAN NOT SEE THE DETAILS. I'M VERY LOST. CAN I INSERT A DETAIL AS A PROFILE?
Mon, Feb 9, 2009 at 4:05:04 PM | CURTAIN WALLS ADDING DETAIL OR PROFILES?
The component you see is a 2D detail component.  It will not show up in a 3D view ... period!  No detail component will.
If you edit this family, you will see the embedded details listed under detail items.  You can pull these out and use them seperately in your projects.  But you will find that they are junk!  They are just imported cad drawings.
Edited on: Mon, Feb 9, 2009 at 4:07:24 PM
Edited on: Mon, Feb 9, 2009 at 4:08:21 PM
Tue, Feb 10, 2009 at 8:08:33 AM | CURTAIN WALLS ADDING DETAIL OR PROFILES?
paulykustomz
paulykustomz Avatar
I agree they are but my boss wants them i am just wondering what the method is to place these 2d elements. so that if I cut my curtain wall I will see a detail of the mullions
Tue, Feb 10, 2009 at 8:19:51 AM | CURTAIN WALLS ADDING DETAIL OR PROFILES?
tim123
4 Stars: 19 Votes
You will need to model them to see them in 3d.
Tue, Feb 10, 2009 at 6:17:12 PM | CURTAIN WALLS ADDING DETAIL OR PROFILES?
robinballew
robinballew Avatar
3 Stars: 4 Votes
Revit can't model the interior detail of the profile exactly. It sounds weird but some of the details are too small. Revit can only handle object down to about 1/256".
BallewDesigns.com
Adding mullions to curtain walls
Thu, Jan 27, 2011 at 12:08:53 PM
curtain walls in legends
Tue, Feb 23, 2010 at 9:50:10 AM
14
Raking curtain walls, adding tags to Shop Front glazing
Tue, Mar 7, 2006 at 9:35:59 PM
curtain walls
Thu, May 18, 2006 at 2:17:11 PM
Curtain Wall - Intersection at Mullions
Thu, Jun 23, 2011 at 6:03:32 PM
Page generation time: 1.8735
