54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Import SketchUp
Fri, Feb 6, 2009 at 9:40:58 PM | Import SketchUp
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
instructions for importing sketchup file is lying..
1. Create an in-place family in a Revit project..(okay i'm in the mass editor)
2. Click File menu > Import/Link > CAD Formats.
3. In the Import/Link dialog, navigate to the folder thatcontains the SketchUp file.
4. For Files of Type, select the SKP file type.
5. Select the file to import.
Cannot open "C:\Documents and Settings\All Users\Application Data\Autodesk\RAC 2009\Training\Common\buildings.skp".  ????????
Sat, Feb 7, 2009 at 4:59:01 AM | Import SketchUp
coreed
coreed Avatar
4 Stars: 16 Votes
have you gone thru the process of installing the training/tutorial files?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Feb 7, 2009 at 5:05:28 AM | Import SketchUp
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
the training files are in their folders- what do you mean "install" training files?
Sat, Feb 7, 2009 at 5:27:07 AM | Import SketchUp
coreed
coreed Avatar
4 Stars: 16 Votes
Revit no longer installs tutorial files when you install revit. when you attempt to access the tutorials for the first time after install, you should get a screen instructing you on how to install them.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Feb 7, 2009 at 6:21:37 AM | Import SketchUp
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
still not sure why you are using the word "install" to
describe the location of a file..
if the file is there it's there.. if it's not there then
there is nothing to highlight and try to open..
i tried to open the buildings.skp file- it is there
but i get a message that it cannot be opened..
i wish i knew why..
Sat, Feb 7, 2009 at 6:34:24 AM | Import SketchUp
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
also if the file was not there you could not get that
message telling you the name of the file it cannot open..
Sat, Feb 7, 2009 at 6:54:24 AM | Import SketchUp
coreed
coreed Avatar
4 Stars: 16 Votes
then the file is corrupt or of a version that can't be open by your version of Revit. but if your file is from Autodesk then version conflict is probably not the problem.try this one
Edited on: Sat, Feb 7, 2009 at 7:02:14 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Feb 7, 2009 at 2:29:26 PM | Import SketchUp
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks very much for your help coreed..(the famous coreed)
i copied that file to my documents folder-i opened revit 09- i create mass and namethe mass- i go to import CAD- i set Files of type: SketchUp Files (*.skp) withall default- i navigate to the file in my documents and click open and revit tells methis:
Cannot open "C:\Documents and Settings\no\My Documents\52539_buildings.skp".
i can't imagine anything else to do..
i can export it from SketchUp as DWG and import that- but not skp..
so many deep dark secrets with revit thatmost of the 350,000 seats are not producinganything.. but that makes it more fun for me..
Sat, Feb 7, 2009 at 2:33:44 PM | Import SketchUp
4 Stars: 203 Votes
Wierd.....
Sat, Feb 7, 2009 at 2:56:46 PM | Import SketchUp
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
How complex is the .skp file?
Revit can only handle so many faces...but it should tell you this.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Sat, Feb 7, 2009 at 3:02:06 PM | Import SketchUp
#11
4 Stars: 203 Votes
Brett, the image I post above is the .SKP file...
Sat, Feb 7, 2009 at 5:05:31 PM | Import SketchUp
#12
coreed
coreed Avatar
4 Stars: 16 Votes
assuming that you have access rights to folders on your computer, if your are using the latest, Web Update 3 Build (20081118_1045) of Revit , then i can't image anything else to do also. Revit will run without all modules being properly install. until you attempt to do something as you have, there seems to be no problem. if you can't import such a simple model, then i betting that your problem laids somewhere in that area.
If you solve your issue, please let us know what the solution was that we may note it for future reference.
best regards,
Edited on: Sat, Feb 7, 2009 at 5:15:45 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Feb 8, 2009 at 3:00:23 AM | Import SketchUp
#13
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
there was no reason for failed skp import- every file and folder was in the right place..
two months of downloading trial programs plus virus and scamwear invasions and it
was definitly time to reformat..
now everything is in the right place again and everything works fine and i feel fresh
and clean.. lol   thanks everyone and thanks coreed..
Sketchup imported into Revit Error and Crash
Wed, Nov 12, 2008 at 5:17:12 PM
problems importing sketchup
Thu, Nov 24, 2011 at 4:10:19 AM
Sketchup To Revit Problems *Please Help*
Thu, Mar 12, 2009 at 9:21:29 AM
PLEASE HELP! Revit + Sketchup intol Artlantis
Sat, Jun 7, 2014 at 6:26:28 AM
13
How to import sketchup models into revit 2014
Fri, Aug 5, 2016 at 9:29:15 AM
Page generation time: 0.3700
