74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Leader Line Line weights
Fri, Feb 6, 2009 at 6:56:19 PM | Leader Line Line weights
everist
3 Stars: 2 Votes
Hello,
I am having difficulty getting my leader lines to dosplay correctly. One extends form text, and the other extends from a multi-category tag. The multi category tag leader is displaying heavier than I would lik eit to. I would think that there would be a "leader line" object style under object styles, or that I would be clued in looking at the line weights in the multi-category tag family, but not so. There is some inconsistency comewhere.
See attached multi-category tag andimage showing the problem. I'm using R-ARC 2009.
Sat, Feb 7, 2009 at 7:26:00 AM | Leader Line Line weights
tim123
4 Stars: 19 Votes
Go to object styles and look for multi category tags.  You can adjust the leader lineweight there.
Sat, Feb 7, 2009 at 10:47:57 AM | Leader Line Line weights
everist
3 Stars: 2 Votes
A ha! thanks!
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
How to match .CTB line weights with Revit
Fri, Dec 5, 2008 at 4:11:55 PM
Linked File line weights
Thu, Feb 2, 2012 at 1:08:00 PM
Detail Lines Follow Model Line Weights Problem
Fri, Sep 9, 2011 at 9:55:51 AM
Page generation time: 0.5727
