81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> Tagging site plan. Filled Regions?
4 Posts No Rating |
My office has just switched over to Revit and I'm doing a site plan. I'm pretty much brand new at it, I've had a bit of training...Anyways I've ended up doing the existing site plan in line drawings just because the survey I was using was flat and I didnt want to go edit everything in that drawing. Now I'm putting down filled regions to show things like asphalt, grass, concrete, etc. I would like to use a tag to show what the materials are but I cant get the filled region to be tagable, obviously it isnt tagable, or I am not doing something wrong. Is there any way I can tag the filled region? Or is there another alternative to tagging the areas I want to? Thanks
Do you mean tag or keynote? Obviously - filled regions are not model elements so how could they tag? If you are using keynotes, select user from your keynote and then point to a model element and pick your keynote. Change the keynote to free end and then move it to your filled region. YOU MUST REMEMBER - THIS IS A SMART KEYNOTE AND IT THINKS YOU ARE KEYNOTING A MODEL ELEMENT. IF THAT MODEL ELEMENT (which may be clear across the sheet) IS TURNED OFF OR DELETED, YOUR KEYNOTE WILL GO AWAY. A fix for this is to place a model family that just has an invisible line in it and place that in your filled region.
4 Posts No Rating |
Well I actually did mean keynote now that I think of it more. And I didnt know that filled regions are not model elements, I am brand new to this program. Thanks for the answer, Ill try it out.
Filled Regions and families |
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions - How to make them show in all views |
Thu, Nov 21, 2013 at 3:53:29 PM
filled in regions |
Mon, May 2, 2005 at 1:08:09 AM
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Region Not Moving |
Wed, Jun 10, 2009 at 9:18:11 AM
Members: | 2056800 | Objects: | 23074 | Forum Posts: | 152249 | Job Listings: | 3 |
