63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Revit Architure
Hi all. I got to print a drawing in 1:250 and i want to know what line weights i uses. Is it 1:200 or 1:500 or does is pick one at random. My boss want a wery specifik look. Nicolai
Revit uses a 16 lines Weights, go to Settings and there you have "Line Weight, Line Pattern and Line Styles" and in Object Styles you can change what you want... Check your HELP menu....
![4 Stars: 19 Votes](/images/stars_4.gif) |
Good question. I cannot see a way to control this. I think that Revit adjusts the line weights to suit the custom scale - see the attached view. The 1/250 view shows linewights slightly thicker than the 1/200 view.
should roof rafter on top of the roof or under the roof. |
Tue, Jul 28, 2009 at 12:41:36 PM
Taper Insulation sloping flat roofs |
Wed, Nov 28, 2007 at 4:12:20 PM
Wall Panel System |
Tue, Mar 24, 2009 at 10:24:27 AM
Revit for Construction Documents [ 1 2 ] |
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ] |
Mon, Jan 17, 2011 at 11:27:39 AM
18
Members: | 2013578 | Objects: | 22931 | Forum Posts: | 152193 | Job Listings: | 3 |
