52 Users Online (51 Members):
Forums >> Revit Structure >> Technical Support >> Amending Construction Start/End Extension
56 Posts No Rating |
Within the Element properties of any beam it has the Construction Sub Category with Start and End Extension. This is as standard set to -12.5 on my model. Is there a way as standard to change this to say -100 so any new beams (and the existing ones is have drawn) show with this larger extension (this is needed to ease reading for engineers and site erectors) Cheers Allan
37 Posts No Rating |
I think the only way is to edit the beam family... But if so, you're gonna adjust every different type of beam seperately. So it's not really easy to do. But if you want it all the time it might be usefull. Greetings, Frank
Objects being cut |
Thu, Mar 8, 2018 at 3:15:13 PM
Beam start/end extension |
Fri, Feb 12, 2010 at 10:59:48 AM
Any way to determine which end is Beam/Joist Start or End |
Mon, Feb 1, 2010 at 7:10:23 AM
Spiral Stair I Need to start at 90 degrees and end at 90 degrees [ 1 2 ] |
Wed, Feb 19, 2014 at 12:40:38 PM
15
Extended 2 1/2" joist end with a 5"+ seat bearing? |
Thu, Sep 29, 2011 at 3:07:20 PM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
