Forums >> Revit Building >> Technical Support >> Ceiling Mounted Family Visibility in Floor Plan
Tue, Feb 3, 2009 at 5:58:10 PM | Ceiling Mounted Family Visibility in Floor Plan
astew426
Hello All,
 I have a few large ceiling-mounted specialty equipment items that I would like to show up as overhead or hidden lines on my floor plan.  From what I can tell, the only way for the outlines of the objects to show is by outlining the objects with hidden lines in the family editor, but even then, if I import them into my project, the whole object shows up on the floor plan because the hidden lines are below the cut line.  Is there anyway to get around this?  Thanks for the help.
Tue, Feb 3, 2009 at 6:09:24 PM | Ceiling Mounted Family Visibility in Floor Plan
coreed
coreed Avatar
4 Stars: 16 Votes
one option that you could try is to specfic that all the other objects other than the hidden lines not to display in plan.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Feb 3, 2009 at 6:54:50 PM | Ceiling Mounted Family Visibility in Floor Plan
astew426
coreed, thank for the response, but is there a way to choose objects to show in RCP but not in Floor Plan?  When adjusting visibility, I am only given the option of RCP/Floor Plan.
Tue, Feb 3, 2009 at 7:48:39 PM | Ceiling Mounted Family Visibility in Floor Plan
coreed
coreed Avatar
4 Stars: 16 Votes
no there isn't. i just meant  set your hidden lines to display and nothing esle. atleast it wouldn't be shown as solid. to do what you want you will probably have to setup some sub-catagories in your family.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Ceiling Mounted Receptacles
Mon, Mar 19, 2012 at 12:19:14 PM
Changing family from wall mounted to ceiling mounted
Mon, Nov 16, 2009 at 2:19:09 PM
Need help with family categories!!!!!!
Wed, Dec 3, 2008 at 8:43:09 PM
Ceiling mounted light family
Tue, Feb 1, 2005 at 9:04:23 PM
How to make a floor plan level into a ceiling level plan in Revit MEP
Tue, Apr 12, 2011 at 7:09:06 AM
Page generation time: 2.1973
