96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> perspective angle
3 Posts No Rating |
HI, I am rendering interior view of a room with outdoor view. When I'd used camera to shoot a view from corner of room, I got really small view of outdoor area due to perspective angle. What I want to know that can you changed angles or diminished point of perspective? I want things far away from camera is bigger. Please can somebody help me with this? Thanks Mino
![4 Stars: 19 Votes](/images/stars_4.gif) |
Adjust your camera angle. You can hide the wall behind the camera to move it back and view a larger part of the room.
1 Posts No Rating |
How do you adjust the camera angle? I'm using Revit 2012 and can't figure it out.
Thanks.
Two things here.
- Camera "lens". Revit uses a near normal "lens" and this stops distortion. You can in essance widen that lens by grabbing the grips on the sides of your viw and stretching them out. Be careful - it will distort.
- Normal camera view do not work well in interiors. Therefore, I do like tim123 suggests and I place the camera outside the room. Then I hide the walls that block my views. This is more like most interior renderings.
Perspective Problem |
Fri, Jun 26, 2009 at 12:13:43 PM
Sectional Perspective NOT cutting in the N,S,E and W direction |
Mon, Oct 3, 2011 at 2:29:47 PM
Building Material Patterns disapear at tight perspective angle |
Sun, Aug 10, 2014 at 3:25:39 PM
Wishlist - Default perspective 3d view |
Fri, May 2, 2014 at 9:31:09 AM
Linework Blue Grip in Perspective? |
Wed, May 29, 2013 at 8:10:21 AM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
