142 Users Online (140 Members):
Forums >> Revit Building >> Technical Support >> curtain walls
Can't get curtain doors and panels to load. Any tricks?
when you say can't load do you mean into the drawings or into the curtain wall?
if you are loading a curtain door or oanel that already exist in the drawings it wil not look like it's loading.
if you are trying to replace a curtain wall panel with a door, make sure you are selecting the panel, once selected go to the drop menu(next to properties) and replace with your curtain wall door. note, you cannot replace with normal doors...
Remember curtain wall doors and windows will not appear with your normal doors and windows lists...
You need to select the panel that you wish the door/window to be located then choose from the drop down menu the appropriate replacement as suggested by Eldad.
HTH.
Angled Curtain Walls - fillets and nested |
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls |
Mon, Nov 7, 2011 at 10:28:33 AM
Curtain Walls |
Wed, Apr 16, 2008 at 1:30:46 PM
curtain walls in legends |
Tue, Feb 23, 2010 at 9:50:09 AM
14
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Members: | 2030725 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
