24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> concrete panel system not sure what the best method it *****picture included
Mon, Feb 2, 2009 at 8:29:13 AM | concrete panel system not sure what the best method it *****picture included
paulykustomz
paulykustomz Avatar
so we have a project for the renovation of a schools exterior and though we have the model created we are not sure how to construct the exterior. has anyone ever attempted this type of exterior sytem? Right now we are trying a exterior wall with reveals. the problem is we can only add in colored filled regions in the elevations to represent the different colored panels. theother option I thought of was to create a curtain wall with different colored exterior finishes on same wall types. but we want to find the appropriate and correct way to do this. all opinions are welcome. thanks in advance guys.
Mon, Feb 2, 2009 at 8:35:38 AM | concrete panel system not sure what the best method it *****picture included
I would use one wall type for the brick portion and another single wall type for the upper area (except the black).  This appears to be an eifs/stucco wwall with different finish areas.  The horizontal and vertical reveals are the right wal to go here and you can split the face of the eifs exterior walls and "pour" on the finish you need in the different areas.
Mon, Feb 2, 2009 at 8:36:50 AM | concrete panel system not sure what the best method it *****picture included
4 Stars: 203 Votes
I can't see very well the wall but if the wall is straight i think i use "Reveals" to divide the panels and then use the "Split face" and "Paint" to assign different Materials/Colors to the panels....
Mon, Feb 2, 2009 at 8:38:11 AM | concrete panel system not sure what the best method it *****picture included
KingRevit
4 Stars: 12 Votes
i'd definatley use curtain wall eith curtain panels for this
Mon, Feb 2, 2009 at 11:48:25 AM | concrete panel system not sure what the best method it *****picture included
paulykustomz
paulykustomz Avatar
thank you all once again. I think typhoon knew exactly what I was looking for. thank you soooooooooooooo much.
Fri, Jun 27, 2014 at 8:31:04 AM | concrete panel system not sure what the best method it *****picture included
scowy
Hi Pauly,
I am doing the exact same thing for a building of mine.
Did you find the method below worked well or would you change anything?
Were there any pitfalls?
customerized curtain panel doesn't work with the irreglar shaped panel?
Sat, Jul 10, 2010 at 1:48:42 PM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
missing empty curtain wall system panel
Thu, Aug 4, 2016 at 7:17:33 AM
Dimensioning a concrete panel w/ openings in elevation view
Tue, Mar 25, 2008 at 3:07:22 PM
Page generation time: 3.4663
