43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> MAKING A CUSTOM WALL
![3 Stars: 4 Votes](/images/stars_3.gif) |
hi i have run into a problem...iam working in revit for the first time and for starters i decided to try to recreate a building designed by well known architect like TOYO ITO i picked the TOD's BUILDING and now iam struggling trying to put the walls together....they are a 12inch concrete walls with a unique pattern of zelkova trees emboded into them problem that i have is that since some of the WINDOWS (openings) turn the corner i have no clue how to make the walls come together at these points....i have posted a rendering of what i have so far basically what i did is that i drew every elevation seperately and then extruded it using the solid extrusion tool in revit architecture 2009....problem is that corners dont meet i mean they are not connected...is there a way to make that happen?
I would use regular walls and corner windows. I believe there is a corner window on REVITCITY that you can modify BUT ... this is going to be very hard for a newbe.
well i think you are right i started it off the wrong thing i should have just created regular perimeter walls and then punch my irregular openings by custom creating windows like the corner window that you mentioned....i thought that i can build my walls first and then fill the voids in with windows....thanks for inspiring me....
Making a Custom Wall w/ Hrz. planks on Studs |
Mon, May 25, 2009 at 7:31:13 PM
Rendering light sources within a custom curtain wall panel |
Mon, Sep 26, 2011 at 2:59:09 PM
custom wall type |
Sun, May 12, 2013 at 8:31:38 AM
How do I make custom wall types publicly accessible? |
Sun, Apr 4, 2010 at 2:17:08 PM
Creating custom millwork with reveals and counter tops. custom dining seating |
Sun, Dec 19, 2010 at 8:42:59 AM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
