84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Aligning Annotations & Views
Thu, Jan 29, 2009 at 3:33:56 PM | Aligning Annotations & Views
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
So in my Revit Training Class I ran into an issue: When I attempted to place a Dimension string, I found that there was nothing to snap to...  this upset me.  Not just because AutoCAD could do it, but because I began drafting on the board.  When board drafting you space annotations, dimensions and views in a rather mathmatical fashion.  It is technical drawing that we're doing here, not just an art project.  Dimension lines are spaced at a regular distance from objects.  Views are centered in their alloted space and so on.  When i brought this issue to the instructor, he simly brushed it off and said that i was being far too nit-picky.  But I ask you this:  What is the point of having dimensions that can snap to each other at a regular distance, when they can't do the same to the model?  It creates dimension strings at different distances on different axis with respect to the model.
Here's my thought...  Why not allow annotative objects and views to snap to / allign to reference planes or a similar "go between"? I realize that annotative objects and model objects are entirely different and that's likely why they don't commuticate to each other, but somehow there needs to be something to bridge that gap to create a level of consistency in a drawing.
I really appreciate how similar to board drafting Revit is, and how fluid and intuitive the interface can be, but these are things that one would not eyeball in any drawing done by hand; why would we allow a computer program which is designed to be more accurate than a hand drawn sheet guess on something that we would measure?
Thu, Jan 29, 2009 at 3:38:46 PM | Aligning Annotations & Views
3.5 Stars: 395 Votes
Revit has a built in spacing of dimension strings that is pretty good.  As you are placing your stacked dimension, you will see an obvious snap at a nice interval.  Strings that are not continuous will also snap to each other as look as your window is open far enough for Revit to see the association.
Thu, Jan 29, 2009 at 5:52:36 PM | Aligning Annotations & Views
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
Yes, dimensions can snap to each other, but it's getting the base point right for the first dimension string to which i'm referring.  Firms generally have standards that say that the first dimension line should be say for instance 1/2" or 3/4" from the object you're dimensioning.  I have as of yet not found a way to make that happen, other than drawing a reference plane, or line and nudging the dimension line 'til it matches.  All of the subsequent dimensions will snap at regular intervals... it's just that first one that has nothing to snap to.
Revit 2010 - It's a good thing... Stop Fighting it.
Tue, Mar 31, 2009 at 5:23:15 AM | Aligning Annotations & Views
FJ22
I totally feel you MrMoo. The same goes for placing a view at a sheet. I would like to put a same kind of floor on the same place as the level above or underneath.
Off course I do know that the drawings aren't going to be better or worse if they are on the exact same position. But it's just a case of working consistantly, that is what I'm telling my new colleagues all the time.
If you do things at a certain matter (in stead of just dropping a view any place you want), in the end you will find out that your work is getting a better result.
Aligning views
Thu, Mar 20, 2008 at 6:27:30 AM
Elevation Annotations in Linked Files - RAC2008
Sun, Feb 22, 2009 at 12:42:25 PM
Adding notes / annotations to views - how controled?
Mon, Feb 4, 2008 at 10:50:09 AM
Aligning of views!
Wed, Sep 5, 2007 at 6:59:36 AM
what is the fastest way to turn off annotations for linked revit files?
Mon, Apr 18, 2011 at 3:33:30 PM
Page generation time: 0.7112
