42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Glass Handrail
Wed, Jan 28, 2009 at 4:48:14 PM | Glass Handrail
mtelford
5 Stars: 7 Votes
I am trying to create a new handrail that has a stainless steel top rail with stainless steel supports every 4'-0".  The space in between the supports is to be a single sheet of 1/4" tempered glass. (There will obviously need to be a SS bottom rail 3 1/2" AFF to support the glass).  However, when I try to modify the handrail system, using a sheet of glass isn't an option.  Do I need to create a new family which is a "rail" that is 1/4"x 36"?  This seems like kind of a conveluted way of doing this.
Wed, Jan 28, 2009 at 5:43:01 PM | Glass Handrail
rvgbrusa
I went through similar situation which I wanted a custom handrail.
I created another family from scratch with the desired specification.
I hope this helps...
Ron
Wed, Jan 28, 2009 at 6:13:07 PM | Glass Handrail
jarosa
jarosa Avatar
4 Stars: 5 Votes
The glass panels will be ballusters. Revit has some in the library or you can create your own family.
HTH,
John
Thu, Jan 29, 2009 at 9:48:16 AM | Glass Handrail
If the glass panels are solid post to post, model the panels as a rail and yes, it can be glass, wood or whatever you want.
If the glass panels are to be kept short of the supports, it may be best to model this as several railings in the same place.  One railing is just a glass rail.  You will need multiples of this ... one for each section - or this could be one-inplace family.  The other railing has your posts and top rail.
Thu, Jan 29, 2009 at 11:53:00 AM | Glass Handrail
mtelford
5 Stars: 7 Votes
I'm looking @ this family file (it's just the one downloaded from the Revit site) in order to get ideas on how to build my own.  I just don't know why it is at an angle.  What is the benefit of doing this?  How are they making this?  Basically, does anyone have a tutorial to explain this?
Thu, Jan 29, 2009 at 11:57:33 AM | Glass Handrail
tim123
4 Stars: 19 Votes
It is so that it can be used on a stair or ramp - the angle can be set to zero.
Thu, Jan 29, 2009 at 4:32:06 PM | Glass Handrail
mtelford
5 Stars: 7 Votes
Thanks for all of your imput.  I did lots of trial and error to figure this out.  I ended up creating new profile families for the top and bottom rails.  I also created new families for the metal baluster and the glass panel (actually a simple baluster, not a boluster panel).  My last question is in regards to clamps that will hold the glass panel in place.  I want to use a simple metal and rubber clamp about 12" o.c.  Should I: a) model one as a mass, copy it into the proper places, and then group all of them with the handrail? or b) create the glass as a baluster panel which includes these clamps (this would make sure that the clamps don't get lost if the handrail gets moved)?
 Image included below.
Glass handrail
Wed, Aug 8, 2012 at 10:44:13 AM
Glass balustrade handrail
Wed, Oct 12, 2016 at 3:28:15 PM
Glass Balustrade with side mounted handrail
Mon, Nov 18, 2013 at 11:31:01 PM
Handrail with glass panel problem
Tue, Mar 4, 2008 at 5:51:49 PM
Handrail without Balusters
Wed, Oct 2, 2019 at 4:04:40 PM
Page generation time: 0.3693
