129 Users Online (128 Members):
Forums >> Revit Building >> Technical Support >> Selecting Invisible Void Sweeps
25 Posts No Rating |
When I create a void sweep and the cut geometry, i then finish the mass. That void 'orange' void sweep disappears and doesn't show up with masses on. How can I easily find that void sweep to selct it and edit it. It sometime takes me several views and several minutes to find it. Is ther an easy way?
In the "mass family" or "In Place" you can use the "Crossing selection" and go to the filter like in the image attached OR you also can use the "TAB" key "when you go with the mouse to the objects) to alternate the object tyou want to select....
pattern issue-void cutting through wall and sweeps |
Fri, Sep 23, 2011 at 2:24:08 PM
Void Sweeps |
Thu, Nov 24, 2005 at 10:31:45 PM
Void Sweeps within Window Family |
Tue, Mar 25, 2008 at 10:26:05 AM
Wall reveals and sweeps being 'over-ridden' by wall based void family. |
Fri, Jan 22, 2010 at 4:39:24 AM
Turning off sweeps in an elevation view? |
Mon, Dec 6, 2010 at 9:05:03 AM
Members: | 2030612 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
