108 Users Online (107 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Curved Dormer Roof
Wed, Jan 28, 2009 at 12:38:39 PM | Curved Dormer Roof
aprilac6
I am trying to cut a dormer opening in a pitched roof and the dormer roof is curved.  When I use the dormer opening tool and pick the points to cut Revit tells me that the opening is not completely defined and the opening will not be made.  I am using Revit 2009.  I also attached two images showing the roof.
Wed, Jan 28, 2009 at 1:05:09 PM | Curved Dormer Roof
4 Stars: 202 Votes
You can do that in several ways...
Wed, Jan 28, 2009 at 1:39:09 PM | Curved Dormer Roof
aprilac6
I tried the vertical opening the opening by face and the dormer opening and I get the same results.  See the attached image.  I need the cuts to be horizontal at the point where the two roofs meet and to be vertical where the wall and roofs meet.
Wed, Jan 28, 2009 at 2:03:11 PM | Curved Dormer Roof
Adnanito
3 Stars: 2 Votes
I don't know if the shaft opening works... what do u think???!
Edited on: Wed, Jan 28, 2009 at 2:09:03 PM
Moh_Adnan_Alj
Wed, Jan 28, 2009 at 2:04:13 PM | Curved Dormer Roof
4 Stars: 202 Votes
OPENING BY FACE....
Wed, Jan 28, 2009 at 2:19:50 PM | Curved Dormer Roof
Adnanito
3 Stars: 2 Votes
y typ???????????? the shaft doesn't work ?
Moh_Adnan_Alj
Wed, Jan 28, 2009 at 2:27:55 PM | Curved Dormer Roof
4 Stars: 202 Votes
Yes AD, and APRIL do you need "vertical" to floor or "Perpendicular" to roof???
Wed, Jan 28, 2009 at 4:40:06 PM | Curved Dormer Roof
4 Stars: 202 Votes
OR you can use "Dormer Opening" if this is what do you need....
Wed, Jan 28, 2009 at 5:32:24 PM | Curved Dormer Roof
aprilac6
That is what I need but it doesn't work for me with the curved dormer roof.
Thu, Jan 29, 2009 at 1:56:43 PM | Curved Dormer Roof
4 Stars: 202 Votes
Hi, I put a simple model here attached so you can check "DORMER OPENING"...
Tue, Feb 15, 2011 at 12:57:46 AM | Curved Dormer Roof
#11
MartinAM
Hello.
I kow this is a very old thread, but I have to ask.
Typhoon: How did you created this dormer opening? Did you put some curved walls to get dormer opening lines to snap or is there another way? It is driving me crazy not beeing abble to sketch.
Martin
One of my dreams is to master Revit. I have long way to go before achieveing this goal, buy I am learing new things every day getting me closer  and closer.
Tue, Feb 15, 2011 at 1:31:58 PM | Curved Dormer Roof
#12
4 Stars: 202 Votes
Watch the video: http://screencast.com/t/ltyxDPHwVj
DORMER ROOF
Sun, Mar 20, 2005 at 6:46:01 PM
Dormer roof not joining
Wed, Jan 6, 2010 at 12:56:28 PM
Dormer
Wed, Jul 18, 2007 at 10:09:50 AM
Creating dormer on roof
Thu, Aug 26, 2010 at 12:55:41 PM
demolition for new dormer
Mon, Aug 24, 2009 at 1:48:58 AM
Page generation time: 0.9074
