51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> material legend to shows materials
Tue, Jan 27, 2009 at 8:52:25 PM | material legend to shows materials
puzzle
4 Stars: 10 Votes
is it possible to make a legend that shows the materials eg colour, surface pattern etc. couldn't find anything in help
Macca
Sunshine Coast
QLD Australia
Wed, Jan 28, 2009 at 8:20:39 AM | material legend to shows materials
You can place jpg images on sheets and in legends but you would need to print these differently than your CD documents ... unless you are doing those in color.
Wed, Jan 28, 2009 at 11:20:56 AM | material legend to shows materials
tim123
4 Stars: 19 Votes
You can do this with family members such as windows by dragging them from the families in the project browser into a legend view.  One way that you could work around to get a legend for walls is to create small sections of wall showing the different finishes and hide them in views or place them outside the crop boundaries.  If this is a problem, export the view and import it into a drafting view and erase the walls from the actual project - see image.
Tue, Jan 3, 2012 at 10:23:40 AM | material legend to shows materials
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I'm setting up templates for the office drawing set and have run into a similar issue.  With Revit 2012 now, is there any intuitive way to create a general material legend showing hatches?  I know how to create a legend component, but then I can only change that to a wall type, etc., but not materials.  My workaround so far has been creating small filled regions with the hatch then annotating them, but this seems clumsy by Revit standards.  Am I missing something?
Materials Legend/Project Parameters
Thu, Oct 10, 2013 at 3:09:33 PM
Material Legend or Finish Legend
Tue, Oct 13, 2020 at 1:29:13 PM
13
Applying materials to new families
Mon, Jun 19, 2017 at 10:28:03 AM
Materials vs Finishes question - where does information go?
Thu, Jan 5, 2012 at 11:35:32 AM
VIEWING LEGEND COMPONENTS PROPERLY
Tue, Apr 14, 2009 at 10:04:02 AM
Page generation time: 1.5062
