154 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Creating Asphalt Drives
Wed, Jun 8, 2005 at 11:17:50 PM | Creating Asphalt Drives
joesrd
Looking to create Asphalt drives in toposurface that follow the grades, that also have a thickness that can be viewed when a section is cut. Any suggestions would help. I have done split region and subregions but they do not have a thickness, so I can't see them in 3D
Thu, Jun 9, 2005 at 12:28:37 AM | RE: Creating Asphalt Drives
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
True they don't have a thickness but you still should see them in 3D?? Unfortunately the only way you are going to get a thickness is to use floors, and floors can only fall in one direction. We typicallly use topography then use walls, floors, in-place families to fill in any holes. Its true currently the site tools are limited.
Revit and solid state hard drives
Mon, Feb 2, 2009 at 9:31:29 AM
Should the OS and Revit be on separate drives
Wed, Oct 1, 2014 at 11:58:29 AM
Revit 2011 Network Drives Disconecting for Windows Vista
Tue, Sep 21, 2010 at 2:05:40 PM
align Revit's asphalt shingle roofing in plan view to sloping side
Wed, Aug 12, 2020 at 4:47:29 PM
Revit architecture on Macbook pro i7 with flashdrive7??
Wed, Oct 19, 2011 at 4:44:28 PM
Page generation time: 1.9649
