Forums >> Revit Building >> Technical Support >> imported revit structure and no visibility beneath
Tue, Jan 27, 2009 at 11:58:52 AM | imported revit structure and no visibility beneath
minsky
1 Stars: 1 Votes
revit arch 2009
I have an imported revit structure model that doubled the levels.  I turned it into a group (don't tell me I shouldn't have done that, the project is too far along now.)  the problem I have is that room boundry and model lines are NOT visible on plans.  I deleted the imported levels and they are there, but they seem to be beneath the structure group. HOW do I make these show in order to resize rooms?
Tue, Jan 27, 2009 at 11:59:50 AM | imported revit structure and no visibility beneath
minsky
1 Stars: 1 Votes
and when I hide the group, room boundry lines are still not visible.
Tue, Jan 27, 2009 at 1:26:28 PM | imported revit structure and no visibility beneath
mbergin
You can try over-riding the Lines > Room Separation Lines in the Visibility/Graphics parameters for the view, also, in VG, turn on the Reference and Interior Fill so that they will show up in your room.  If you have Structure that is hiding the separation lines, you can temporarily hide the Structure or Over-ride the graphics in View to make them transparent while you are re-sizing the Rooms.
Michael Bergin
Intern Architect / BIM Specialist
CMSS Architects, PC
Virginia Beach, Washington DC, Richmond
Tue, Jan 27, 2009 at 1:41:52 PM | imported revit structure and no visibility beneath
minsky
1 Stars: 1 Votes
VG is on.  I'm afraid it's got something to do with the combined levels from both projects.  Revit combined some levels and not others, left both sets of level there, and even gave some levels new names.
Tue, Jan 27, 2009 at 2:06:14 PM | imported revit structure and no visibility beneath
3.5 Stars: 401 Votes
Sounds like you really have problems.  If you had linked the model, the levels should have been the same .
Did you turn off the floors?
Tue, Jan 27, 2009 at 2:07:34 PM | imported revit structure and no visibility beneath
BTW - If the two models don't share common levels, the room boundry lines in the link will not show.
Tue, Jan 27, 2009 at 2:29:28 PM | imported revit structure and no visibility beneath
minsky
1 Stars: 1 Votes
at the begining, importing and linking the models, even though I imported the structure at "zero" level, it did not come in at this level, it came in slightly below it.  It took me a while, looking at the elevation levels, to realize there were a whole array of levels that the structure came with, of course, and I highlighted the structure, and matched the levels accordingly.  Somewhere along the way, when we were having trouble editing the linked structure file, someone made the structure a group, and  this combined certain levels.  When I delete one of the "matched" levels, the rooms show, but I'm losing several key walls.  Anyway, I was able to get into the group and move the grid to where I wanted it. I gave up on the rooms.  Deleted them and did everyting in filled regions.  At least I know what not to do during the next linked project.
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
Imported .dwg File Visibility Settings
Mon, Mar 14, 2011 at 5:29:06 PM
imported file
Tue, Aug 17, 2010 at 9:28:42 AM
How to remove the layer beneath on planview?
Wed, Dec 4, 2013 at 2:47:04 PM
Images uderlayed beneath 3-d views (Revit 2008)
Tue, Jun 10, 2008 at 1:37:16 PM
Page generation time: 1.8504
