115 Users Online (114 Members):
Forums >> Revit Structure >> Technical Support >> Draw order of Linked Revit Files
10 Posts No Rating |
When i link the architects Revit File to my file, his drawing is showing up ontop of my drawing which is covering up my walls and other items. Very annoying!! Please help me this is driving me nuts! PS It is not a DWG link so linking to current view doesn't work in this case. Thanks in advance David
12 Posts No Rating |
Hi. I am having the same problem now. Did you ever find a solution?
iwong, under V/G you have to select a custom set up for the visibility settings for the linked revit file. Then under model graphics and annotations (you need to make sure you click the box that says "show categories from all disciplines" select all and click the transparent box beside the halftone column. This was the only way i could figure out how to get this to work out. Let me know how this works.
Yes, that seems to be the general consensus as the only work-around right now.
Thank you!
Draw order of linked DWGs |
Thu, Jun 21, 2007 at 9:14:00 AM
draw order |
Wed, Aug 20, 2008 at 8:26:33 AM
draw order in revit 2010 |
Tue, Sep 23, 2014 at 1:24:31 PM
autocad linked files and refresh |
Tue, Apr 7, 2009 at 2:12:36 PM
Draw Order in Family Editor |
Wed, Aug 28, 2013 at 3:07:31 PM
Members: | 2042348 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
